Suggests songs for playlists based on the content (ex: on the artist, album or gender of the songs)
Example on practice:
You have an Alex G song on your playlist
You have another Alex G song on your library which is not on the Playlist
Symfonium recommends it with a button to add
Now the music you have forgotten to add is there
Makes easier to make playlists and add contents after a new song is downloaded, you may also forget to add a Song and the resource will make it easier for add it
Rediscover your own library: many users have songs they’ve saved but never added to their playlists. This brings them back without manual searching.
Less effort to stay organized: instead of remembering to add every track by an artist or album, the suggestion does the work and the user confirms with a single tap.
More cohesive playlists: if a playlist includes one song by an artist, the user will likely want the rest of that artist’s songs there too, which helps keep the playlist’s mood and style consistent.
User stays in control: nothing is added automatically. Each suggestion comes with an add button, so the user decides what goes in.
More value from local and server libraries: Symfonium gets more out of the music already on the device or on a server (Subsonic, Jellyfin, etc.), without relying on streaming services.
Differentiation: recommendations based on a user’s own collection are less common than streaming-service recommendations, and they suit users who value control over their music.
Foundation for future features: the same similarity logic (artist, album, genre) could support radio, automatic mixes, or smart sorting.
[ NOTE: This specific part was written by Claude AI ]
So if you make a playlist that has one Alex G song in it, and you have another 30 Alex G songs in the library, you’d want Symfonium to ask you 30 times if you want to add the other 30 Alex G songs, i.e. once per song?
Honestly, this sounds only useful for one specific use-case, and it’d be detrimental for anyone who has a large library: Now let’s add another 30 tracks from different artists to the same playlist and then the user would be swamped with a bunch of “spam”.
If what you need is all the tracks by Alex G from your library, just add Alex G as an artist to the playlist!
That’s why configurations exist you could only show one or two songs from the same artist, or album or even blacklist it from the current suggestions, why would you suggest only a artist on a playlist? It don’t really make sense
You may want to create your own personal “Best of” or “Greatest Hits” style playlist for one single artist, without including the songs you dislike.
After speaking to ChatGPT to try to work out what I’m missing here
Ah, I think I understand better now. You’re proposing a small, configurable set of optional recommendations, rather than suggesting every matching track.
How would Symfonium decide which tracks to recommend, though? If I’ve got hundreds of tracks matching the artists or genres already in a playlist, what determines which two or three are actually relevant?
there are a lot of ways to do that like the user rating, how many times the user has listened to this song, how many similar songs are on the playlist or how small is the amount of this type of music on the playlist (This include, gender, artist, album, year period, etc)
My apologies, I was assuming that the example from the OP was specifically the behaviour that you wanted to see, rather than one focussed example from a far wider idea!
