Subsonic Sync Failing
Sync consistently failing for 24 days, despite no changes to Subsonic server. (It did work prior to this)
Navidrome
  1. Open settings
  2. Go to “sync manager” and click “sync” for subsonic server
Media has been added to the server and Web view reflects this. All other elements of connection (caching new songs, scrobbling) work fine.
shocking
Update to version 15.1 see changelog.
Same issue. 15.0.1 is the latest available in play store even after enabling beta, how do I get 15.1?
It took some digging, but you need to use the beta f-Droid repo. You can set it up to sync or just grab the apk directly
