Stuck on NPS if no queue open
Beta
Logs are from Beta but affects public version as well.
If “Now Playing” is the only option selected in the “Main Navigation Entries” menu, it becomes impossible to leave the NPS when no queue is loaded.
All
Beware, you will be locked into NPS after following these steps!
Settings > Interface > Navigation and Media start > Main Navigation Entries
Select ONLY "Now Playing* from the list
Upon exiting settings, the app will open the NPS. If no queue is open, app will display only “Nothing is playing”.
No buttons are present to leave NPS. Cannot use gesture to collapse NPS (Compact Player is disabled when using Navigation entry for NPS). Android’s Back Input simply exits the app.
If media is playing, you can at least navigate from string taps and then use the floating Settings button to fix.
Fortunately I can use the API to load my theme or I’d be stuck.
Celorien_SoftLock
