Beta
Stuck in database sync.
The app synced around 800 artists and the progress not move any longer.
The server is airsonic-pulse, a subsonic varient.
The log was sent under name as luckyluke.
Subsonic (Open)
Open app and set the server.
use token as auth.
sync a large library.
luckyluke
Tolriq
August 18, 2026, 7:22am
2
2026-08-18 01:50:29.188 Verbose SubsonicLogger <-- [408] {
"subsonic-response" : {
"status" : "ok",
"version" : "1.16.1",
"type" : "airsonic-pulse",
"openSubsonic" : true,
"serverVersion" : "13.2.0.20260721110130",
"openSubsonicExtensions" : {
"openSubsonicExtension" : [ {
"name" : "formPost",
"versions" : [ 1 ]
"name" : "transcodeOffset",
"versions" : [ 1 ]
"name" : "songLyrics",
"versions" : [ 1 ]
"name" : "indexBasedQueue",
"versions" : [ 1 ]
"name" : "apiKeyAuthentication",
"versions" : [ 1 ]
"name" : "getPodcastEpisode",
"versions" : [ 1 ]
2026-08-18 01:50:29.192 Error SubsonicLogger Error (0/0)
kn1: Expected BEGIN_ARRAY but was BEGIN_OBJECT at path $.subsonic-response.openSubsonicExtensions
at ew4.m(r8-map-id-
The server returns invalid answers.
Same for search3
2026-08-18 01:50:34.846 Verbose SubsonicLogger <-- [477] 200 http://xxxxx/rest/search3.view?query=%22%22&musicFolderId=7&songOffset=0&songCount=0&albumOffset=0&albumCount=0&artistOffset=2000&artistCount=500&apiKey=REDACTED&v=1.13.0&c=Symfonium&f=json (1935ms, unknown-length body)
It keeps returning the same data over and over and over even with the offset increasing.
Looks like vibe coded server that needs auditing and fixing
