Is it possible for you to make the Marquee effect only apply to the long lines of a string? (Currently Marquee applies to the entire string, rather than per-line.)
Multi-line strings don’t look great when Marquee is active because the short portions will also scroll.
Marquee effect would be more useful for strings with different line lengths.
Inspired by the changes to trailing newline. This is one of two solutions I came up with for my theme. (The other doesn’t involve a feature request
I completely understand if this isn’t possible due to the way the text boxes are handled. The simple solution for 90% of users will just be to use two String slots instead of one. (Which I think I can manage as well, so consider this request to be low priority.)
Sorry for delay, site was down for a bit? String in question is the “The Jiggly Jellies \n Sir Leopold Beaumont…” portion and is Center justified.
Current behavior (2x recording):
Ideal Behavior (top line stays in place):
Cherry Picked example of why current behavior isn’t the best (8x recording):
In this last example, it takes 30s for the top line to be visible and 1m30s for it to return ![]()
