My library is ridiculously large (acknowledged ) and it breaks song mix. Song mix appears to start but never finishes. Sometimes it seems to kill the app.
Once offline (succeeds), a few times online (does not finish)
debug-20230806_231931.zip (16.5 KB)
This is to be expected The algo needs to load a lot of data in memory to do the mix and your phone can’t handle that amount.
I’ll try to add some workaround for such large library but the algo won’t be as good as it in those cases.
This is working perfectly now, thank you!!
