Some tracks (opus files extracted from youtube) not marked as played
You mean the scrobbling part? That the track is not marked as played?
Just tested and the track appeared in the last played. I must say I am using Lightweight Music Server and not Navidrome fwiw
Sorry I’m not being clear enough. With the workaround (disabling the opus decoder) it works again now. Without that it still doesn’t scrobble.
Weird. But anyway, what’s the point in playing without the workaround and not being able to seek?
Or I might be missing something.
Often it doesn’t matter so much, but with version 0.24 it would have been helpful to be able to switch when the ffmpeg decoder stopped working.
Unfortunately you cannot enable/disable the opus decoder without changing the configuration file as far as I know…
Is there anything else to be fixed, or is everything ok with version >= 0.24.1?
