[SOLVED] Need to add the same media provider for LAN
Hi!
I had a Navidrome media provider that was added for LAN. I used it by connecting to my LAN via WireGuard.
Then I decided to eliminate the VPN chain and to just forwarded Navidrome port (via Nginx reverse proxy HTTPS) into Internet. So I went and added this new (old) provider to S and it started indexing it. After it finished, it became clear that it just… doubled everything.
Is there a way to have the same provider added twice: for LAN and for WAN?
Well you can hide a provider by tapping it in the Source Filter menu (funnel icon). That would hide all the duplicates while still allowing you to switch the active one when needed.
Just add the secondary connection in the same provider.
Thank you very much, it works!
