SMB playlists not loading
Playlists won’t load over smb. Thought it was a path thing, but they work with other apps. Tried relative and absolute paths. Tried the three button (nothing happens). Tried add to playlist and get error saying no songs. Tried making a test song in a single folder still no work.
Log suggests some java timeout, but dunno why when aimp and rhythmbox can get files from the SMB drive
SMB
File browser, select playlist, three button import/three button add to playlist
Incoherent_fishface
Your logs show timeouts while reading the playlist files themselves, before Symfonium processes the paths inside them. Changing relative or absolute paths therefore won’t resolve this particular failure.
What device/software provides the SMB share, and which version? Please also attach your smallest failing playlist and confirm whether an individual music file from that same folder plays in Symfonium. Those details will help narrow down why these reads stall.
Also try 15.1.0 see changelog here to install.
Only download the app the other day so should be latest from play store. No updates available there, maybe it needs higher Android.
Dunno how to upload but the test playlist I tried had one song with various paths cause I thought it was a path issue. So I renamed a file and put in a test folder.
File share is off a be230 TP-Link router
#EXTM3U
#EXTINF:641,A Thousand Nails - Aathma
smb://192.168.0.1/g/Shared Music/test/test.m4a
test/test.m4a
/test/test.m4a
./test/test.m4a
../test/test.m4a
Is the version that I’m using the problem? Nothing in the change log suggests fixes to this specific issue.
