Smart Flow not working
Beta
Smart Flow’s sonic-analysis-based modes (Transition Maestro / Echo Match / Steady Vibes) stopped working. The options are selectable but produce no effect — the current track plays normally, but no tracks are added to the queue.
Device type: Phone (Samsung S23, Android)
Media provider: Navidrome (self-hosted), with the AudioMuse-AI-NV-plugin for sonic analysis (AudioMuse-AI backend)
Versions: Navidrome and the AudioMuse-AI-NV-plugin are both on current/latest versions.
Troubleshooting already completed:
  • Confirmed AudioMuse-AI analysis job is fully complete
  • Confirmed via Navidrome web UI that Instant Mix works correctly (pulls sonically similar tracks)
  • Confirmed Radio Mix in Symfonium works correctly (queues tracks fine)
  • Confirmed no track ratings are used in my library (ruled out the low-rating exclusion behaviour)
  • Confirmed Navidrome and the AudioMuse-AI-NV-plugin are both running and healthy (checked admin/plugin status)
  • Ruled out network/connectivity as a cause — tested while actively streaming non-cached/non-downloaded tracks successfully, on the same connection
  • Forced a fresh connection re-test and removed/re-added the Navidrome server in Symfonium — no change
  • Forced a full library re-sync (not just a quick sync) in Symfonium — no change
This is my first time posting an issue – apologies if I am not doing it correctly.
Navidrome
  1. Play any track.
  2. Open Smart Flow and select Transition Maestro, Echo Match, or Steady Vibes.
  3. Track plays, but no tracks are inserted/queued.
Logs attached via the app’s built-in log submission. Happy to provide any further detail or repro steps needed.
atyourenemies
Your logs are empty … I need logs reproducing the issue.
Sorry, my mistake. I think I have submitted it correctly now. Thank you for your quick response!
2026-08-18 20:13:24.173 Verbose SubsonicLogger  <-- [954] {"subsonic-response":{"status":"failed","version":"1.16.1","type":"navidrome","serverVersion":"0.63.2 (be10f89c)","openSubsonic":true,"error":{"code":0,"message":"Internal Server Error: plugin call failed: AudioMuse-AI returned status 401"}}}
Thank you – and thanks for the great app.
