Smart (context-aware) network transcoding / caching policies
Introduce context-aware playback & caching rules that automatically adapt your audio source selection, transcoding, and fallback behavior based on the current network environment and host reachability.
Streaming my hi-res library (often 10s of MBs per track) burns through mobile data quickly. Right now, transcoding rules are essentially all-or-nothing settings per provider, as well as caching either being utilized or not. This forces a compromise: to save cellular data, I have to keep transcoding enabled across the board, leaving me stuck listening to compressed audio even when I’m at home on Wi-Fi with plenty of bandwidth.
Full hi-res audio at home and compressed streaming on the go automatically. This could also be extended with an “offline/fallback” toggle, which could ensure cached tracks play seamlessly (take over) when the connectivity drops completely or the host goes down.
All
Thanks for the suggestion. You can already configure transcoding separately for mobile data and Wi-Fi under Settings → Playback → Decoding and transcoding. For your use case, I’d set Mobile maximum bitrate to your preferred compressed bitrate and Wi-Fi maximum bitrate to Original. Configure these limits in Symfonium, and make sure your server allows original files rather than forcing transcoding for every connection.
For finer control per Wi-Fi network, you can use Symfonium’s API with an automation app such as Tasker to change the Wi-Fi transcoding setting when you connect to a particular network—for example, Original on your home Wi-Fi and a lower bitrate elsewhere.
Thank you! I hadn’t realized there’s a transcoding settings page separate from the provider configuration. This solves the main problem I listed. My apologies, and thanks again, I absolutely love the app and really appreciate all the work you put into it.
