Navidrome playlists can have a description in addition to a title. It is exposed through the Subsonic API in the playlist’s comment field. Other clients such as Feishin display it under the playlist title, but Symfonium only shows the title.
I would like Symfonium to display the playlist description/comment when the provider supplies one, for example in the playlist header or details screen.
I have a large number of playlists generated automatically on Navidrome, and the description explains what each one contains. For example, a playlist titled “Abandoned Ships” has the description “Loved once but not played in 2+ years — what happened?”. Without it, many playlist titles are hard to interpret on their own.
Playlists are easier to identify and understand, especially when there are many of them.
Symfonium would match what Navidrome and Feishin already show, so the playlist looks the same across clients.
It could also help with other servers that support playlist comments.
Other application solutions
Feishin shows the Navidrome playlist description directly below the title.
Server: Navidrome, via Subsonic/OpenSubsonic API.
The description is returned in the comment field of the playlist object (getPlaylists / getPlaylist).
A read-only display would be enough for me, with no editing needed.
