The current state is displaying no toast message when creating a smart playlist from a smart filter.
Problem Description
The smart playlist is created if you clicked on “Save” but it’s not created if you do not click on “Save” but anywhere outside of the currently opened window.
Solution
A toast Message displaying “Smart Playlist created” or “Smart Playlist created” for one or two seconds after you saved it.
