Hi Guys,
sorry for coming up with this topic again. But setting a ‘Fortsetzungspunkt’ does not work very reliable.
No matter If I press the Pause Button in the app, the play/pause button on my earphones or simply remove the earphones. Sometimes it works playing a folder or single file. No idea what to change in the app. Maybe it is a bug?
Kind regards
I have used the german word because I dont know this word in english language and this is how it is called in the app in german language.
I can not explain it better as i did.
The app does not saved/stores the paused title/Album reliable.
I will try tweaking the min percantage. The track you see on the buttom in the Screenshot was paused at about 20%. Maybe your advice will help
I start the app, press play either on a given file or folder, press pause in the app if I want to stop the playback. The paused track or album should appear in the list on the main screen as paused album/track.
My issue is, sometimes the paused album/track appears in this list and sometimes it does not appear in this list.
But as i wrote, guess I have to deal with it.
No problem.
Thx for your time
2025-06-02 16:54:58.544 Verbose MediaStateUpdater Set resume from state change at 10935 for 02 Titel 01.mp3 [0,16/0.9]-[10935-73351/5000]
2025-06-02 16:55:04.108 Verbose MediaStateUpdater Set resume from state change at 14000 for 02 Titel 01.mp3 [0,20/0.9]-[14000-73351/5000]
2025-06-02 16:55:10.745 Verbose MediaStateUpdater Set resume from state change at 19415 for 02 Titel 01.mp3 [0,27/0.9]-[19415-73351/5000]
2025-06-02 18:52:46.972 Verbose MediaStateUpdater Set resume from media change at 35646 for 02 Titel 01.mp3 [0,50/0.95]-[35646-73351/0]
2025-06-02 18:52:51.121 Verbose MediaStateUpdater Set resume from state change at 4140 for 02 Titel 02.mp3 [0,04/0.95]-[4140-130429/0]
In those logs there’s resume points set at 50% for the title 01 and at 4% for title 02.
But those files are not present in Symfonium.
Have you synced the provider to have the files in the library ?
