Scrolling to the top should not happen
Beta
I setup the home screen in a way that everything fits inside the available space so I don’t have to scroll, however, I still see an unnecesary scrolling to the top and I haven’t found the way to fix it.
You can see in action the issue in the uploaded video.
I’m not sure if a log is necessary for this as this is more a design flaw rather than a bug in the app.
  1. Open the app
  2. Scroll the screen up
  3. The interface scrolls up as if there were more hidden elements on the bottom but there aren’t.
Symfonium Home Tab.mp4
I’m guessing you have the Compact Player enabled? It takes space at the bottom, even when nothing is currently playing.
If you set the player as a Navigation Entry (so that it has a tab I stead of the Compact Player) then that bottom space is no longer reserved.
You’re right, it’s the compact player as that’s the default one, I reduced the size of the icons to a point where there is no scroll, however, if the compact player is not active, there shouldn’t be an scrolling until it actually appears.
If there was no space reserved, the Compact Player would cover up the bottom of your Home Page every time you start playing something. So you would tap something at the bottom and then have to scroll up again, because what you just tapped is being covered.
Simulated example:
20261005_133350
I will note that it is possible to still have a single-page Home layout with no scrolling. But you do still have to leave enough space for the Compact Player if you are using it.
I’ve had the exact sizes mapped for a while for a similar reason–I like keeping my things aligned a certain way. I’ll post them elsewhere later, but for your convenience:
Compact Player
Default: 60
Medium: 75
Large: 90
Floating Player: +8
Floating Player bottom margin: +value
Bottom Progress Bar: +4
For reference, a media row set to “List - Single line” style takes exactly 55pts of space per item.
