A limited amount of icons that can be assigned via a custom pack. (So let’s say a maximum of 3 custom icons).
This would introduce icons that can’t be replicated via UNICODE symbols.
Custom icons would be use inside custom strings, allowing for custom “quality” indicators / anything (since custom strings have an extensive condition system).
A reserved icon could also be used to populate the “Home Icon” section, if modified to allow for custom icons inside the icon pack. (I do see the value in keeping a simple image picker though…)
This would probably introduce the same treatment that other parts of the UI got (alignment, custom color, etc…)
I found out that this is theoretically possible via the icon pack, but I haven’t been able to display these icons via “%icon:custom.0%”.
Looks like that portion of the page was just added. So it’s not usable yet in the current beta.
