Replaygain not applied
Replaygain is not applied to tracks when track mode is active and songs have replaygain values in metadata.
Navidrome
  1. Open output settings for output device
  2. Select ‘Track’ for Replay gain setting
  3. Play any playlist containing tracks from multiple albums
  4. Volume difference between tracks very noticeable
Removed all r128 tags from media after discovering known issue with beets adding 0 value r128 tags even if non-zero Replaygain tags exist and refreshed library
triclops
If you can upload the track anywhere I can have a look for you.
I may have fixed it by deleting all downloads and re-downloading them. It seemed to be an issue only in offline mode. I tried everything else I could to resync or reset metadata first. It would be nice to have an option to do that without having to resort to redownloading everything. Also a visual indicator if replaygain values are being applied in the player, like next to the the other file info (format, bitrate, etc) similar to other players I’ve used.
I have an open feature request for just that here:
