Replay Gain not working for two albums
There are two albums that have been recently added to my server that have replay gain but it does not seem to be working.
Navidrome
  1. Open App
  2. Play Song with proper Replay Gain
  3. Go to song without proper Replay Gain
  4. Go back to normal gain song and hear the difference
Two albums are Half Me - DOGMA and Entheos - Empty on the inside
I did make a similar issue about this awhile ago but that was because I had the album downloaded before the gain was added I have checked and removed my cache.
I have removed the albums from navidrome server and re added them did not fix the issue.
When played via navidrom or ‘feishinh’ on computer the gain seems to work just fine.
PS logs are played with no sound if that does not work I can make more when not at work.
Blxter
The muted logs are fine. They show no ReplayGain tags reaching the player for “Hell Is a Part of Me”, “Fear Is the New Belief” and “Empty on the Inside”, so those tracks get 0 dB adjustment. The surrounding tracks get about −13 dB.
For Navidrome playback, Symfonium currently reads ReplayGain from the audio file. It doesn’t use the server’s separate ReplayGain API values, so values shown in Navidrome don’t guarantee that Symfonium receives them.
Could you upload the original “Fear Is the New Belief” FLAC from your server to https://upload.symfonium.app and include a description mentioning this ReplayGain problem? I can then check the embedded tags and compare them with what reaches playback.
I have uploaded the song. I use the same replay gain called rsgain for all of my files.
If you enabled playback cache clear it too ?
Yup that worked. Sorry I did not know this setting existed I looked for it but clearly did not find it. Weird that it only happens to a couple albums. Thanks so much love the app :slight_smile:
