Repeat-one loops partial transcoded stream instead of full track
Follow-up of t/10417. Symfonium 15.1.0 (latest), Navidrome 0.64.0, server transcoding FLAC → Opus 320.
  • On resume, Symfonium requested the stream with offset=340 (track is 439 s). From then on it treats that partial stream as the whole track: the UI shows 1:39 and seeking doesn’t work.
  • With repeat-one it loops only that tail (22 cycles, no new stream request) and never returns to 0:00.
  • This morning the offset was at the very end: it looped the last ~100 ms for 20 min and scrobbled every loop (~1,350 scrobbles to Last.fm).
  • Separately: 32,751 getTranscodeDecision calls for the same track in 39 min (up to 28/s).
Playback rapidly loops, it does not continue normally. Last.fm scrobbling is done by Navidrome (Symfonium → Navidrome → Last.fm), no other scrobbler app.
Navidrome
  1. Navidrome provider with server transcoding to Opus (any long track).
  2. Play the track and seek to ~5:40, or close the app so the queue is restored at a late position.
  3. Resume playback: the app requests offset=X and shows duration = track length - X.
  4. Enable repeat-one and let it reach the end: it loops the tail (from X) instead of the full track. If X is very close to the end, it loops the last few ms and every loop is scrobbled.
  5. Watch the server log: getTranscodeDecision is called ~10-28 times per second for as long as playback continues.
Device: Sony Xperia 1 (XQ-FE54), Android 16, local playback (no casting).
Occurrence time: 2026-10-17, repro 16:53 → 17:32 CEST (14:53 → 15:32 UTC)
Server excerpt (UTC):
14:53:23 reportPlayback positionMs=340000 state=paused
14:53:23 [server] Streaming TRANSCODED requestOffset=340 cached=false seekable=false opus/320
14:53:23 reportPlayback positionMs=680000 state=playing ← 2x offset, beyond track length
14:53:26 getTranscodeStream offset=340 → 200, 3,949,911 bytes
14:53:34 getTranscodeStream offset=340 → 200 (cached, seekable)
14:54:06 getTranscodeStream offset=340 → 206, 803,014 bytes ← last stream request
14:55:55 onwards: reportPlayback 30 s / 60 s / 90 s → 0 every ~98 s, 22 cycles until 15:32, no further stream requests
dugi - repeat one logs
Thanks Tolriq!
