If “Remember Smart flow mode” is set to Yes, and the Smart flow mode is set to Transition Maestro, the user can set a configurable # of tracks that can be inserted. The default is 5.
When playing a new playlist, the Smart flow mode is still set to Transition Maestro, but the # of tracks resets to 5, instead of retaining the # the user set.
Navidrome
- Make sure Remember Smart flow mode is Yes
- Start any playlist
- Set Smart flow mode to Transition Maestro
- Set Max. tracks to insert to any value other than 5
- Change to a new playlist
- Max. tracks to insert changes to 5
evilnick_transition_maestro
