I have a couple of playlists set up with the offline cache feature. However, every now and then, I’ll come across a song where I need to edit the tags or data, such as fixing a typo or adding lyrics.
I was wondering if it would be possible to add a “refresh” button for songs. Something where you can select the song(s) or go to More Actions and have it re-cache just what you selected.
Also, there could be a playlist setting to regularly refresh data on the songs in the playlist.
I believe this will solve the problem of having to remove a playlist from the cache, wait for the songs to be deleted from the phone’s storage, re-cache the playlist, and wait for the songs to download every time you edit a song’s data.
This will help users streamline their experience with the app, allowing them to fix their music files’ data and see the results much faster.
