Radio Mix only queues seed artist tracks
When starting a Radio Mix from an Artist Page (e.g. The Beatles), the resulting queue contains only tracks from the Beatles, even though Jellyfin returns a valid list of similar artists and those artists have playable tracks in the library.
Upload description: knechtling
From the reverse proxy logs I can see the request:
proxy-1  | nginx.1     | tester.com IP_ADDR - - \[18/Jan/2026:19:41:14 +0000\] “GET /Items/c8adebb786bc3c4f0c996e6b1a318a0c/Similar?userId=USER_ID&limit=20 HTTP/2.0” 200 7845 “-” “Symfonium/13.7.0 (Linux;Android 10)” “172.18.0.6:8096”
testing the endpoint with curl it returns valid data:
\[root@debian\~\]# curl -sS “https://tester.com/Items/$ARTIST_ID/Similar?userId=$USER_ID&limit=20”   -H “X-Emby-Token: $TOKEN” | jq -r ‘.Items[ ].Id’ | head
6ba23a8964287ed1bffa062822462534
d5d9ad5638934c356a26ed9fc085ebbc
4c140ae49372e9869f978d3a5480d1e7
299cec9f1f019208d2972c3d9502b0b5
cb29e77900fd0de40fb74f1dccec0610
15faa8822a10cc079c443de5bf56dfc5
d04c35a081ea852263f04bf14142a7b2
db7ca85a73fa436ec0198fc73db30740
2da0501c6ead433f7e25107d78b320c9
baaaf93f6513a76e1bad420cb99513a7
  1. Open The Album Artists Page
  2. Press the 3 dots next to a Album Artist
  3. Select Radio Mix
This is probably the usual Jellyfin bug having multiple internal ids for the artists and returning what they want depending on the case :frowning:
None of the artist Ids returned by the end point are found by Symfonium in it’s database so can’t be used.
Thanks for your reply.
I confirmed Jellyfin duplication issue.
Example: “Genesis” exists under multiple Jellyfin internal IDs:
  • 1b63b20055a1b4bff692e0e3f7c91a84
  • c7fcf9d1ebd9551b28e1bf5c77dbc256
Both have identical ProviderIds:
AudioDbArtist=119229
MusicBrainzArtist=8e3fcd7d-bda1-4ca0-b987-b8528d2ee74e
I also see many similar artists returned by /Items/Similar having 2–3 internal IDs for the exact same Name.
Is this still the same issue from 5 years ago: Problematic API issue with artists / albums · Issue #6048 · jellyfin/jellyfin · GitHub
If yes, thats really a bummer that in 5 years nothing was seemingly done to address this api issue.
Do you know of any workarounds one can do to get sonic analysis features still working in symfonium + jellyfin?
If not is there a music server you’d recommend that has good compatibility with symfonium?
Great app by the way. Absolutely love it. Keep up the good work.
It is the same issue, I’m horrible to have a closed source app, and despite their answer about the API being non sense :slight_smile:
And no I do not have a workaround. I recommend GitHub - epoupon/lms: Lightweight Music Server. Access your self-hosted music using a web interface. or Navidrome but not Jellyfin at all for music but for the moment there’s no AudioMuse AI there.
