Queue/Now Playing UI Not Updating After Song Rating
When rating a song from the queue screen, the new rating does not appear in the queue or the now playing screen, even though the rating is correctly updated in the library view.
Expected Behavior:
After rating a song from the queue, the new rating should immediately update in both the queue and the now playing screen.
Actual Behavior:
The new rating only appears in the library view, not in the queue or now playing screens until you create a new listening queue.
Upload description: collectuniversal
Issue occurs consistently.
Tested on version: 13.7.0 (127660)
  1. Open Symfonium and start playing any song.
  2. Go to the “Now Playing” screen.
  3. Open the listening queue.
  4. Tap the context menu (three dots) for any song in the queue.
  5. Select “More actions.”
  6. Select “Change user rating.”
  7. Apply a new rating and press “Rate.”
  8. Observe:
  • The song’s rating in the listening queue still shows the old value.
  • Returning to the Now Playing screen, the rating also shows the old value.
  • If you check the song in the Library view, you’ll see the new rating is applied there.
Subsonic / Navidrome
