Question about offlinestatus String Values
Hello Tolriq! I just have a small question about the values returned by the offlinestatus string.
I see that for my local files, offlinestatus returns “1”.
Is this value used specifically for the “Local device” provider? Or can cached files from other providers also return this value?
All
No issue present
I am trying to make an “Offline status indicator” that does not show for local media. The docs site has the following example string:
{⬇ Offline%|offlinestatus!=empty%}
But this displays for local files as well, since offlinestatus==“1”. If that value is only for local files, I can easily exclude it. But I don’t know if other providers’ media might also return “1” for offlinestatus.
In the NPS preview it returns 0, 1, and 10001 so I assume there can be many values.
I’m also trying to avoid checking against provider name because I assume “Local device” name varies by language.
None
You can’t 1 is cached, local device have all the files playable offline :wink:
