Question about Album resume points
Hello,
I have a question about Album resume points, both for smart playlists and the home page “continue album listening”.
It does lists the albums I have not finished listening, but pressing plays does not start from the first track unplayed, it starts from the track 1.
Am I missing something? Is it a limitation from the opensubsonic provider?
Upload description: question - no logs
Create an album smart playlist with the filter ”With resume point”
OR
Add the home page folder ”Continue Album listening”
Press play on top. Listening begin from first track.
Please provide the mandatory logs as the dozen messages told you ?
Didn’t think logs where required for this question.
Logs uploaded under ‘whinette’.
Launched playback from home, then from smart playlist.
Well I guess I must be very stupid to put all those messages and checkbox for no reasons then :slight_smile:
Like having to loose time asking them again in the issue.
Can you confirm what play button you actually use ?
Those:
So yes those buttons are play buttons to play the whole content present.
To resume an album you need to press the resume button in the album view.
I thought I was blind as I wasn’t able to see it.
After resetting the settings for the album page, the controls appears. It seems there were hidden behind the album art.
Setting the buttons to ‘below’ achieve what I wanted at first: not having the album art covered by stuff (I disliked that, a lot).
Fyi the settings ‘header’ as the capture below recovers the button controls if they’re set to above.
Subsidiary question, I suppose this is not possible to quickly enqueue / smart playlist these resume points?
Yes the icons can be hidden or not visible with bad configuration, that the side effect of full control.
And no you can’t enqueue multiple resume points else any song resume point would apply when when change song and it would not be nice :slight_smile:
On this, it would be great to have preview for more interface settings :slight_smile:
