Preferred cast device
Ecco la traduzione in inglese:
Thank you, the app finally allows me to access my Jellyfin library in a music-oriented way rather than a general one. It would be useful to be able to set a default cast device so that, at the next startup, the app automatically tries to cast directly to that device. In addition, having the cast icon directly in the player would make it easier to change it “on the fly.” Thanks.
Annoing flow for often casting
Better config for often casting
Check BubbleUpnp
Enable the option Remember last renderer and edit the now playing screen you use to add the cast button. (And please use the search button)
