It is possible to embed both synchronized and unsynchronized lyrics in a music file at the same time. Symfonium then uses the unsynchronized version by default.
It would be great to either set the default to synchronized or make it customizable.
Synchronized lyrics show up if they are there.
Other applications that don’t support the synchronized version can use the unsynchronized lyrics and symfonium still displays the synchronized lyrics
I don’t know any
