Thanks for looking at this. I’ve attached two files:
1. plex-server-log-excerpt.txt is the Plex debug log from 10 October, 19:32–19:46, with tokens, usernames and IPs removed. It shows Symfonium’s decision and start.mp3 requests with maxAudioBitrate=160, and the profile augmentation where the 160 limit is only on flac, mp3 and wav. The add-limitation(add-limitation) entries logged as “ignoring directive” are there too.
2. replay-comparison.txt has the same request for one track (first 240 s), replayed against the server. As Symfonium sends it, Plex serves Opus at about 488 kb/s. With &musicBitrate=160 added, it serves Opus at about 151 kb/s. Plexamp sends that parameter and gets 160 kb/s.
My data usage was around 27 GB total, 22 GB of it on mobile, between 8 and 10 October. I only had logging on for 10 October, so I can’t give you a trustworthy per-day split. If it helps, I can run a clean test: mobile data only, a known set of tracks, and a before/after traffic count.
Replay comparison: Symfonium's request vs the same request with musicBitrate=160
Plex Media Server 1.43.4.10903 (Docker), item /library/metadata/376859 ("We Are One", FLAC, 240 s).
Both requests were replayed against my server with the same client profile as Symfonium's (tokens removed). Same item, same Plex, same output format (Opus).
Raw lines are in plex-server-log-excerpt (log times 19:46:01 and 19:46:04, Oct 10).
A) Request as Symfonium 15.1.0 sends it (maxAudioBitrate=160 only):
GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160
Plex decision: libopus bitrate=512
ffmpeg: -codec:0 libopus -b:0 512k
Bytes returned: 14,645,016 (= about 488 kb/s over 240 s)
B) Same request with &musicBitrate=160 added (the parameter Plexamp sends):
GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160&musicBitrate=160
Plex decision: libopus bitrate=152
ffmpeg: -codec:0 libopus -b:0 152k
Bytes returned: 4,525,391 (= about 151 kb/s over 240 s)
Result: the added parameter cuts the transfer from 14.6 MB to 4.5 MB for the same track, about 3.2x smaller.
Plex Media Server debug log excerpt, 2026-10-10 (Plex 1.43.4.10903). Tokens, usernames, session ids and private IPs removed.
Key lines only, copied verbatim from the sanitized log. Repeated warning lines are shown once per request.
=== 1. Symfonium 15.1.0: decision request (19:32:49) ===
Oct 10, 2026 19:32:49.251 [131435169418040] DEBUG - Request: [127.0.0.1:41156 (WAN)] GET /music/:/transcode/universal/decision?path=%2Flibrary%2Fmetadata%2F376858&protocol=http&directPlay=1&maxAudioBitrate=160&directStream=1&fastSeek=1 (12 live) #c8ef1 GZIP Signed-in Token (user)
=== 2. Profile augmentation sent by Symfonium: the 160 limit is on flac, mp3 and wav only; the Opus target (ogg/opus) has none ===
Oct 10, 2026 19:32:49.251 [131435169418040] DEBUG - [Req#c8ef1/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-limitation(scope=musicCodec&scopeName=flac&type=upperBound&name=audio.bitrate&value=160)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=mp3&type=upperBound&name=audio.bitrate&value=160)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=wav&type=upperBound&name=audio.bitrate&value=160)+add-transcode-target(type=musicProfile&container=ogg&audioCodec=opus&protocol=http&context=streaming)+add-limitation(scope=musicCodec&scopeName=flac&type=upperBound&name=audio.samplingRate&value=384000)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=mp3&type=upperBound&name=audio.samplingRate&value=384000)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=ogg&type=upperBound&name=audio.samplingRate&value=384000)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=opus&type=upperBound&name=audio.samplingRate&value=384000)+add-limitation(add-limitation)+add-limitation(scope=musicCodec&scopeName=wav&type=upperBound&name=audio.samplingRate&value=384000)+add-direct-play-profile(type=musicProfile&container=mp4,mp3,flac,ogg,wav,mkv&videoCodec=*&audioCodec=flac,opus,mp3,ogg,alac,aac,vorbis,pcm,wav&protocol=*)+add-direct-play-profile(type=musicProfile&container=dsf&videoCodec=*&audioCodec=*&protocol=*)+add-transcode-target(type=musicProfile&container=flac&audioCodec=flac&protocol=http&context=streaming)+add-transcode-target(type=musicProfile&container=mp4&audioCodec=aac&protocol=http&context=streaming)+add-transcode-target(type=musicProfile&container=mp3&audioCodec=mp3&protocol=http&context=streaming)
=== 3. Malformed entries (logged 6 times per request, 2 shown) ===
Oct 10, 2026 19:32:49.251 [131435169418040] WARN - [Req#c8ef1/Transcode] ClientProfileExtra: invalid add-limitation directive query string: add-limitation
Oct 10, 2026 19:32:49.251 [131435169418040] WARN - [Req#c8ef1/Transcode] ClientProfileExtra: ignoring directive: add-limitation(add-limitation)
=== 4. Plex's decision: limit applies (1057 > 160) so it transcodes, but picks Opus at 512 kb/s ===
Oct 10, 2026 19:32:49.257 [131435169418040] DEBUG - [Req#c8ef1/Transcode] Session - audio.bitrate limitation applies: 1057 > 160
Oct 10, 2026 19:32:49.258 [131435169418040] DEBUG - [Req#c8ef1/Transcode] Streaming Resource: Reached Decision id=376858 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,This app cannot play this item. The reason is: audio.bitrate limitation applies: 1057 > 160. Transcode=1001,Direct play not available; Conversion OK.) media=(id=357894 part=(id=357894 decision=transcode protocol=http streams=(Audio=(id=489219 decision=transcode bitrate=512 encoder=libopus channels=2 rate=48000))))
=== 5. Symfonium start.mp3 request, ffmpeg bitrate, bytes sent (track 376858) ===
Oct 10, 2026 19:32:49.506 [131435134323512] DEBUG - Request: [127.0.0.1:55266 (WAN)] GET /music/:/transcode/universal/start.mp3?path=%2Flibrary%2Fmetadata%2F376858&protocol=http&directPlay=1&maxAudioBitrate=160&directStream=1&fastSeek=1&path=%2Flibrary%2Fmetadata%2F376858&protocol=http&directPlay=1&maxAudioBitrate=160&directStream=1&fastSeek=1&stripTags=0 (11 live) #c8f33 Signed-in Token (user)
Oct 10, 2026 19:32:49.525 [131435134323512] DEBUG - [Req#c8f33/Transcode/JobRunner] Job running: ... -codec:0 libopus -b:0 512k ... (ffmpeg command shortened)
Oct 10, 2026 19:32:51.828 [131435462916920] DEBUG - Completed: [127.0.0.1:55266] 200 GET /music/:/transcode/universal/start.mp3?path=%2Flibrary%2Fmetadata%2F376858&protocol=http&directPlay=1&maxAudioBitrate=160&directStream=1&fastSeek=1&path=%2Flibrary%2Fmetadata%2F376858&protocol=http&directPlay=1&maxAudioBitrate=160&directStream=1&fastSeek=1&stripTags=0 (17 live) #c8f33 2322ms 9280370 bytes
=== 6. Replay A (19:46:01): item 376859, only maxAudioBitrate=160: libopus 512k, 14,645,016 bytes ===
Oct 10, 2026 19:46:01.280 [131435198749496] DEBUG - Request: [PRIVATE-IP:32980 (Subnet)] GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160&session=REDACTED (9 live) #cc18c Signed-in Token (user)
Oct 10, 2026 19:46:01.283 [131435198749496] DEBUG - [Req#cc18c/Transcode/JobRunner] Job running: ... -codec:0 libopus -b:0 512k ... (ffmpeg command shortened)
Oct 10, 2026 19:46:04.020 [131435462916920] DEBUG - Completed: [PRIVATE-IP:32980] 200 GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160&session=REDACTED (11 live) #cc18c 2740ms 14645016 bytes
=== 7. Replay B (19:46:04): same item, &musicBitrate=160 added: libopus 152k, 4,525,391 bytes ===
Oct 10, 2026 19:46:04.038 [131435223448376] DEBUG - [Req#cc743/Transcode] Streaming Resource: Reached Decision id=376859 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,This app cannot play this item. The reason is: audio.bitrate limitation applies: 1014 > 160. Transcode=1001,Direct play not available; Conversion OK.) media=(id=357895 part=(id=357895 decision=transcode protocol=http streams=(Audio=(id=489220 decision=transcode bitrate=152 encoder=libopus channels=2 rate=48000))))
Oct 10, 2026 19:46:04.043 [131435173731128] DEBUG - Request: [PRIVATE-IP:34042 (Subnet)] GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160&musicBitrate=160&session=REDACTED (11 live) #cc74c Signed-in Token (user)
Oct 10, 2026 19:46:04.058 [131435173731128] DEBUG - [Req#cc74c/Transcode/JobRunner] Job running: ... -codec:0 libopus -b:0 152k ... (ffmpeg command shortened)
Oct 10, 2026 19:46:06.503 [131435462916920] DEBUG - Completed: [PRIVATE-IP:34042] 200 GET /music/:/transcode/universal/start?path=%2Flibrary%2Fmetadata%2F376859&protocol=http&directPlay=1&directStream=1&fastSeek=1&maxAudioBitrate=160&musicBitrate=160&session=REDACTED (16 live) #cc74c 2460ms 4525391 bytes
=== 8. Plexamp for comparison (19:40:42): sends musicBitrate=160, Plex picks Opus 152 kb/s ===
Oct 10, 2026 19:40:42.962 [131435211414328] DEBUG - Request: [PRIVATE-IP:57980 (Subnet)] GET /audio/:/transcode/universal/start?directPlay=0&musicBitrate=160&path=%2Flibrary%2Fmetadata%2F370393&session=REDACTED (20 live) #c9dde TLS GZIP Signed-in Token (user)
Oct 10, 2026 19:40:42.963 [131435211414328] DEBUG - [Req#c9dde/Transcode] TranscodeUniversalRequest: adapting profile with augmentation data: add-transcode-target(replace=true&type=musicProfile&context=streaming&protocol=http&container=ogg&audioCodec=opus)+add-limitation(scope=musicCodec&scopeName=opus&type=upperBound&name=audio.channels&value=2&onlyTranscodes=true&replace=true)
Oct 10, 2026 19:40:42.975 [131435211414328] DEBUG - [Req#c9dde/Transcode/TPU] Streaming Resource: Reached Decision id=370393 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=351792 part=(id=351792 decision=transcode protocol=http streams=(Audio=(id=479795 decision=transcode bitrate=152 encoder=libopus channels=2 rate=48000))))
Displaying plex-server-log-excerpt.txt.
