I have a playlist set up in Emby. I will update the playlist in Emby and then sync it within Symfonium and after it finishes syncing, the sort order is changed. I want it to be sorted by the title at all times. Unsure as to what order it is being sorted in but it seems like it might be in the order they were added to the playlist. The playlist is sorted properly within Emby (by title). Is there a setting or something within the app I am overlooking?
Upload description: corylowry12 sorting issue
- Create a playlist within Emby
- Import the playlist in Symfonium
- Sort playlist in Symfonium
- Update playlist within Emby
- Sync playlist in Symfonium
- The sorting method is reset
Emby
