Playlist folders
Add the ability to sort playlists into groups/folders for organization.
Difficulty finding specific playlists when users have a ton.
Ease of use, customization, and simplicity. This adds another level of organization beyond favoriting playlists.
Spotify has the option to add playlists to folders on the “my library” page.
The folders can be created via a button at the top which then prompts the user to name the folder/group, or when selecting multiple playlists, a new button in the multi select menu will create a folder with the selected playlists in it. It would also be nice to set a custom photo for each folder icon. Playlists can be individually added to a folder by dragging and dropping, or via the 3 dot menu in each playlist.
Duplicate use playlist tags that allows more flexibility.
I very much agree. Just started unsing symfonium and I really miss the playlist organization from spotify I have to admit. I honestly don’t really use my playlist much right now because they are just to hard to find in my very long list
That’s pretty awesome! Thank for letting me know. :slight_smile:
Now is there by any chance a way to add a tag to multiple playlist with ease? Or is it currently only possible to do one by one?
