Player on Android system does often not show Track picture
The Symfonium music player on Android devices frequently encounters an issue where track pictures (album art) do not display correctly on the Android UI media player. This problem occurs across various tracks and albums.
Upload description: Android meda Player
It happens all the time, the cover is available but the android player only shows gray. (Android 14)
There’s no logs uploaded associated with that description (after fixing the typo).
Does it happen always for the same images ?
There should be logs available. If not, I’ll upload some soon for further inspection.
This issue isn’t related to special images; it affects all track covers. I’m not sure if it only occurs in ‘offline’ mode, but I can consistently reproduce the problem.
When I turn off Wi-Fi and skip about 3 songs, the Android System Player turns grey, but the cover in the app remains cached. If I re-enable Wi-Fi, the image loads, but I don’t believe the images are being fetched from the server because I can take the Jellyfin server offline and the images still load.
However, I’m not certain if this is the only scenario where the issue occurs; it’s just the easiest to reproduce intentionally.
Update: I looked on my screenshot again: There the image is not loaded but Wi-Fi is enabled so it doesn’t only happen in offline mode.
I mean if I tell you there’s no logs you already know that I need new ones :slight_smile:
So please provide logs reproducing the issue.
