Player notification returns after being closed on Android 14 (2024)
First i talked about what is being discussed here. And yes, my smartphone is a Samsung (S23 Ultra), and no, it doesn’t happen with any other app. :wink:
I stopped chiming in, but I keep secretly hoping this gets fixed in a future version :wink: Really love this app – just this one annoying bug.
Since this thread got brought back up - I guess my question for @Tolriq is: I know you say this isn’t a bug in Symfonium. Are you suggesting that every other app with media resuming has done some specific coding to support new Samsung devices?
Clearly there’s a fix for this since no other app has this issue and whether Symfonium or Samsung is to blame doesn’t really matter.
Are you open to the idea of maybe adding a few lines of code to better support Samsung phones? Samsung accounts for a large portion of the Android user base and any way you look at it, a cleaner bug-free experience makes the app better for everyone (even if it’s not your bug) :slight_smile:
Also, for what it’s worth – I am a developer and I sincerely appreciate all you’ve done. I know certain Android APIs can be a bit messy. You’re the person with the power here since none of us work for Samsung to fix any issues on their end.
As I said I do not own a Samsung device and won’t purchase one for this considering that this is Android and I barely make money with the app.
And again this is not really a bug it’s the documented wanted behavior of apps supporting resuming to have the media session there for resuming and when the app is started with a queue. The solution is to unpin the media session but Samsung have removed that.
So what you consider a bug, is how Google wants things to happens for modern apps targeting the very last Android SDKs.
If you are able to tell me what Samsung breaks and how to workaround with proper details I can add it, but I won’t purchase every broken devices that exists to workaround all the OEM issues that exists.
Wanted to resonate on this issue. Hoping to get a solution on this. Device: Samsung S24 Ultra with One UI 7 (Android 15).
Enable the option Playback/Advanced / Disable media session restoration …
Just stumbled upon this thread. I have bought and like this app, but this bug annoys me deeply. It just makes no sense, sometimes I go days without using the app, everything is fine, them suddenly the Symphonium icon appears in the lock screen and media player again! Without any interaction with the app at all. I don’t use a Samsung device either.
As a developer myself I understand devs might also get annoyed with these reports, specially since they probably did everything right and it’s some OEMs Android quirks sabotaging them - I believe that - but damn…
Just leaving this post here, not to harass you, but kind of just to say that even if it takes a dirty ugly hack to make this behavior go away I think you should do it. Something should be possible because this is the only media app that I use or have used that does this. Cheers!
The workaround is there and documented in the post just above :wink:
Here, with a Galaxy S23 Ultra running One UI 7, i can confirm that the situation described has, fortunately, been solved for quite some time now.
Same issue here on a regular s23 with oneUI 8.5 (android 16). Surprised at how people have to walk on eggshells to get a message across the developer. Fix this thing, dude. I paid 6 bucks for your app and it’s clearly a bug on YOUR side as this only happens with a YOUR app, as people have tried to make clear countless times.
Before assaulting me and trying to explain things you do not understand read ?
This is a well known Samsung bug that needs workaround, there’s a workaround, so just apply it ?
I had to uninstall the app due to this super annoying bug. Disable/enable media session restoration didn’t work for me. S25 Ultra.
It works for all, provide logs if not, there’s nothing that can be done from this comment.
After the new installation I was hopeful as it seemed to work, but after 20 minutes the notification came back. I enabled disable media session restoration the first thing I did after the installation.
Where do I find the log before I share it with you? I want to know what I’m sharing
As everything all in the docs :wink:
