I was not successful in sending opus files via Upnp to my Wiim Minis.
As a workaround I want to enable Flac transcoding when playing Audio on the Wiim via Upnp.
I can control this in Navidrome via the Symfonium (Lavf) Player.
Unfortunately this is the same player that is utilised when casting to the Wiim via upnp. So I am not able to control the Transcoding setting for the Wiim separately from the local player in the app.
When I parse the Wiim for the playback URL that it pulls the audio from it seems that there is a &c=symfonium part in the URL which identifies the Wiim as Symfonium to Navidrome.
I assume this is passed from Navidrome to the Wiim.
Is there a possibility to change the client to the name of the device that actually plays the audio so it can be identified separately in navidrome?
Upload description: hirsch2k
