I’m not sure what’s going on. After the Pixel 11 USB exclusive issue got fixed. I’ve been using that and everything is fine most of the time. I am using the latest 15.1 release.
But occasionally playback pauses after a song is finished, and the next song doesn’t start. I’m not sure how to capture a report when I can’t reliably repro the issue. I COULD leave debug mode on but that might result in a huge report.
If it’s not a consistent problem then yeah, best you can do is leave Debug mode on until it happens. Then once it happens, make a note of the current time (the actual time, like on the phone’s clock lol) and immediately disable Debug mode and share the logs with support.
If the log file is too big to be sent in the app, you can save the file to your device from: “Settings → Manage generated files”. Find the “debug.log” in the list (should be at the top) and click the Download button. That saves the file to your device’s “Internal Storage/Download/Symfonium”. After that, you can upload it at upload.symfonium.app
Either way, when you make the post in Support about your issue, make sure to include the time when the issue occurred. That way the dev can skip through most of the log and look at the relevant section.
