Sometimes when I resume a playlist, instead of playing the track I will get a spinning circle progress indicator around the play button, but the track won’t actually begin. I have to switch tracks to get it to actually start playing anything. I have uploaded a log of this happening, I had to leave debugging open for a few days to capture the error, but the problem occured at appproximately 11:20 on 2025-03-04 in the log.
Possible relevant details: The files are local on the device, but cached from Navidrome. Playback is resumed using an API call from Tasker after connection to a bluetooth device.
Ah, thanks! I’ll have to look in to why it timed out. The brings up a different question though. How does it choose between primary and secondary connections for each provider? I have primary as my local network IP and secondary as the external IP. In Musicolet for example, there’s an option to use a specific IP when connected to a certain SSID. Does Symfonium do anything like that? I didn’t see any similar settings
