Playback from Navidrome breaks after OneUI-Update
Beta
After a recent OneUI-Update playback of every file from my Navidrome-server breaks - including those offline available.
Error message is:
Non-supported media format.
From the log:
ERROR_CODE_PARSING_CONTAINER_UNSUPPORTED at 0ms
Software information
•Android-Veriion:16
. Version: S938BXXSBCZG3/S938BOXMBCZG3/S938BXXSBCZG3 • Sicherheitspatch-Ebene: 5. Juli 2026
Tried clearing all caches (including the one in the Android menu), restarted, rebooted, switched off all crossfading or transcoding options. All cache in the app is deactivated.
Playback of local mp3s (non-Navidrome) works flawless.
Navidrome
  1. Playback of any file
Problems originated on 14.1 version (? latest stable version). Tried updating to 15.0, but errors persist.
debug.log
You either need to sync your provider or need to fix your server settings.
2026-08-08 22:43:26.899 Verbose SubsonicLogger ← [656] {“subsonic-response”:{“status”:“failed”,“version”:“1.16.1”,“type”:“navidrome”,“serverVersion”:“0.63.1 (052f10fd)”,“openSubsonic”:true,“error”:{“code”:0,“message”:“failed to make transcode decision”}}}
