Option to prevent restarting queue after last track
An option to prevent looping back to the start of a queue once the last song is reached.
I like to shuffle my massive (Jellyfin) library, so I usually just do a “Track Mix” from the home screen and it queues up 200 random songs. But as I reach the end of the queue, if I “skip” over the last song, the queue starts over again and I end up listening to the same 200 songs because I didn’t realize I need to create a new mix.
This current behavior seems like it should only happen if the “repeat all” option is enabled, but it happens even when that option is disabled.
This makes it clear that the queue is done and that new songs have to be queued.
Other application solutions
Other apps I’ve used typically do the “stop” behavior by default, unless the “repeat all” option is selected. Once the last song in a queue is played/skipped, the playback ends even if the user clicks “next”
I guess the other option would be to create an “infinite” track mix option, where it automatically adds in another 200 songs once the last one is reached, but I assume that a Track Mix queue currenty isn’t any different than other queues, so this seems like way more effort.
Uncheck Circular navigation queue ?
Thanks for the quick reply! Hot diggity, I looked at the “Playback” settings screen multiple times but I guess my brain didn’t parse what that setting was for. Yes, that is exactly the behavior I wanted. Please disregard this request. Thank you!
