Add support to the new getLyricsBySongId | OpenSubsonic enhanced lyrics parameter and format that OS now supports.
The lack of enhanced lyrics on the OpenSubsonic provider.
It would let OpenSubsnonic use the enhanced lyrics, with syllable timing, translations, transliterations, etc, everything that it supports.
All
I’m wondering when they’ll land on Symfonium since they’re now part of the spec. I saw that you helped shape the spec so I assume in the near the near future. (will it be on 14.1.0?)
