OneDrive not able to sync - cannot identify which file causes failure
Hi team,
I cannot get my OneDrive files to successfully sync. I have just uploaded the most recent debug file.
I have tried syncing with different OneDrive folders; to allow sufficient time to sync (as I am aware that I have a lot of files) I have been waiting 12-24+ hours between attempts. I was able to get a partial sync done one time - it synced 3 of the many more than 3 folders. This most recent sync on a different folder failed after less than two minutes. The files are visible and accessible via the Library, but they’re not coming up on the homepage (and if I wanted to navigate via my folder structure, I would be using OneDrive directly!)
My partner has been able to sync his OneDrive to Symfonium over the same network with no issues, so I suspect there is a problem with something in my specific configuration or my specific files. However, I can’t figure out what that problem is!
Upload description: MendraMarie
One Drive
There’s no logs uploaded
I’ve tried to upload again, using the “Manage Symfonium generated files” process. Name is still MendraMarie.
Still not present probably over 100Mb and showing an error. You need to manually upload via https://upload.symfonium.app
I’ve tried that method now.
2025-08-17 10:00:29.066 Verbose OneDriveLogger  <-- [984] HTTP FAILED: java.net.UnknownHostException: Unable to resolve host "graph.microsoft.com": No address associated with hostname
2025-08-17 10:00:29.067 Verbose OneDriveLogger  <-- [364] HTTP FAILED: java.net.UnknownHostException: Unable to resolve host "graph.microsoft.com": No address associated with hostname
Your phone can no more connect after some times.
Also see https://dontkillmyapp.com/ just in case.
thank you, I figured it was something on my side.
