OneDrive No Folders found
After I logged into my onedrive account, Symfonium aks me to choose at least one folder to continue. But in the folder view are no folders visible.
I tested it with google Drive. And there it works.
Upload description: Kulturban
One Drive
In my case, symfonium is no longer accessing Onedrive. This problem started recently. I’m going to open a thread asking the developer for help.
Your log is empty… I need logs reproducing the issue.
Thanks. Today the folders showed up but media playback is super slow. So I may now have a similar issue like you.
I reuploaded it. Hope it worked. The folders show up now. But It seems not to be able to Recognize any files from onedrive, e. G. Making smart playlists does not work.
The sync never finished seems you had a couple of network issues. Just press sync again to restart it.
Sadly this didn’t resolve the issue.
Then provide new logs ?
Hey Tolriq! I gave it another shot. And now it works! Yay, I’m very happy!
Can i ask you another question?
Is there a possibility to choose a folder from the files menu (e. G. A folder in my oneDrive Music directory) and create a playlist with the music from this folder? I know that there is the Smart Playlist FolderName Filter. But that seems to me like a big hussle to do that for every folder.
