NPS String Icon sizing affected by Order
Beta
New in Beta 7
The string icons for Strings 2, 3, & 4 become smaller when exactly three other elements are positioned before them.
All
Demo NPS:
nps-Order Resize-20260628_121442-symfonium.json (37.8 KB)
Set string icons for Strings 2-4, as well as for at least one of the remaining strings.
Use the “Row Order” option to set exactly three other elements above Strings 2-4. These can be Strings 1, 5, 6, and/or any combination of the bars. (Even if Top/Bottom Bar are not set to “Show in Controls panel” and even if Volume Bar is set to “Hidden”)
Play any track and observe that the icons are not the correct size.
Bug does not affect NPS Preview. Only visible in live NPS. Also, this seems to affect Portrait only.
Pic 1: Preview NPS, showing the correct icon sizes (identical size & alignment)
Pic 2: Live NPS, showing incorrect sizes
Pic 3: example of affected Row Order
Luckily this bug affects my main NPS theme, else it may have gone unnoticed.
Celorien_OrderResize
