The “Invert Colors” option for the Progress Bar does not work correctly with the “Animated” progress bar style.
Instead of flipping the played/unplayed colors, only the Played part becomes dark.
(All other styles work correctly.)
Upload description: Celorien_InvertAnimated
Pic 1: Animated bar, default colors
Pic 2: Animated bar, inverted colors
Set progress bar style to “Animated” with any color option. Check the preview, should have two distinct colors.
Now enable the “Invert colors” toggle and check the preview. The “played” part got darker but the “unplayed” is not changed.
