NPS: Color options for progress bar text and media control buttons
New update came out (I shared logs all the same for the version), and it’s implementing the option to choose nps text color.
I have one problem, that it doesn’t allow control on color of the text below progress bar (like time/duration, extra info like speed in my case), and media control button (the pause/play, next, previous, etc. buttons) colors are still limited.
In a sense it could be seen as a bug, that progress bar color setting doesn’t seem to affect sub-progress-bar-texts, but I couldn’t decide if it should be an issue or feature (the way I see it I’m asking for more control to be added).
With that said, I had a specific request, I’m not sure if it’s a big ask, I wish I could control progress bar’s color and subtext separately, i.e. personally I wish to see progress bar be primary and subtext be white/whatever color I wanna set.
Gives more control? In a sense the current update doesn’t solve the problem I posed initially when requesting the feature, as i highlighted how music duration being black on darker bg reduces visibility (not getting to complain, still appreciate the feature).
More control over NPS colors.
First screenshot is the ideal I wanna reach, specific components primary, rest white on darker blurred bg.
Second screenshot shows the subtext and next/previous button in black/darker colors, which I currently wish to control.
I added logs all the same for version info.
IF the settings I’m requesting has already been implemented, do enlighten me.
Yes it does … There’s a text color setting in the progress bar block.
Ohh wait. I missed that. Thanks for the help.
Any plans to add those options for media control buttons?
