Not syncing with funkwhale server
Hello!
I successfully managed to authenticate with the funkwhale instance I’m using (funkwhale.it) but whenever I try to sync the syncing stops after counting the number of artists + 1 album.
I’ve tried it already with another server audio.liberta.vip and the same thing happens.
I can see the artist names as folders in the files section but nothing inside the folders.
Upload description: noauthoritybuturself
2025-09-04 13:59:41.920 Error SubsonicLogger  Error (3/3)
com.google.android.gms.internal.cast.v7: Expected an int but was NULL at path $.subsonic-response.searchResult3.album[47].duration
They again return invalid values. You need to report to them so they fix. Albums duration can’t be null.
is there a way i can import a specific library so i dont run into this problem?
This is a bug in the server software, so any library that have nulls when it should not will fail.
Report to Funkwhale.
ok i understand, what i mean is if there’s a way to sync only specific libraries (like my private library) so i can make sure the album duration on those isnt null
Not possible for now sorry.
