None of DSD file is suported on bluethouh with FIIO m27.
I have tried all type of DSD file.
None of them can even be plaided.
It is just an Information.
Because I don’t mainly use Symfonium on my m27.
But I consider that information can help developpers to make their app more compatible with m27.
Thank you.
Take any DSD file and paire iem on bluethouh with m27 and can not be read.
Thanks for the information that I can do absolutely nothing about Next time please provide the logs else you are just like showing a kid a candy and tell him that he can’t have it …
I’m not 100% sure, I’m a wired headphones kind of guy… but I don’t think bluetooth in general supports DSD. Just in the past couple years CD quality lossless bluetooth protocols have become a thing.
If you want to listen to DSD over bluetooth a) you’ll be transcoding to probably lossy AAC, and b) you’re doing it wrong (imho)
Thanks Franck, I found the Bluetooth failure in your first upload. After your headphones connect, Symfonium still selects the M27’s native DSD output, which fails to initialize. Playing DSD files over Bluetooth requires conversion to PCM first, and that conversion is being bypassed here.
As a workaround, with Bluetooth connected, open Settings > Playback > Output settings and select the active output. If “Disable vendor-specific playback routes” is shown, enable it and retry the same file. Please let me know whether playback starts, or whether that option is absent. Your wired playback can also serve as a temporary workaround.
What ever you see as parameters changed in the log file, im the one who made those changes manually while the player was trying to play DSD files without any success. So if you check properly the log file you may see : there any moment when DSD was played during Bluetooth connexion.
In all situation DSD can not be played via Bluetooth. You can see during iem cable session it plays well and when switched to Bluetooth: it can not be played.
As I said , it was just an information. Probably it is my only fiio m27 which has the problem, you could ask on the forum someone to test it on how fiio m27 Bluetooth and see.
