No possible cast of radio stream with authentification
I can’t cast a radio to my Chromecast Audio.
The problem is for a very specific combination:
Selfhosted radio stream with basic authentification (https:user:[email protected]/stream.mp3) + Symfonium + Chromecast Audio
Changing something from this triplet and everything work:
  • my radio + Symfonium OK
  • my radio + VLC app + chromecast OK
  • another (public) radio + Symfonium + chromecast OK
I’ve tried to enable the proxy by Symfonium mode for the chromecast with no success.
I’ve tried to kill Symfonium, empty cache, restart the local radio stream, with no success
  1. Open Symfonium
  2. Start the radio stream
  3. On the same network than the chromecast, connect to chromecast. Confirmed by the sound notification
Effect : no music, the player no longer advances the timer, it remains stuck at 00:00.
It worked before I add authentification to the radio stream.
Radio stream is coming from a selfhosted service and exposed to the internet with Cloudflare.
Nabulog.log (shared with https://share.symfonium.app/)
Yes Chromecast does not support that kind of basic auth and the proxy mode is skipped for radios due to issues with hls.
I’ll see to support proxy for those when they are direct urls and not hls ones.
OK, thanks!
I’ve just figured out I could format the radio URL differently and append the password with ?auth=
And this works on Chromecast. :+1:
