An option to both make it that when you press the onscreen synced lyrics toggle all the text goes white, and tapping on lyrics won’t jump to that point in the song. Essentially faking non-synced lyrics.
Some songs have different versions, for example, a shortened single version or an extended mix… Sometimes when using a lyrics fetcher, you get the correct lyrics, but for a much longer or shorter version. Being able to essentially on-the-fly make them “non synced” would be helpful (as explained above).
Expands customization of synced lyrics toggling, and can assist with incorrect synced lyrics.
It can also help with accidentally getting the synced lyrics for a studio version in a live version.
