Any idea on how to change the mode that it’s in?
I told you twice already
Show the settings screenshot.
Ok so test with duck ?
I can do that soon. I tried setting to duck before and there was no change. You want me to set to duck and do another log?
I’ve uploaded the updated files for after I set to Duck, force stop the app, reopen it, and attempt to play a song.
Seems it isn’t using “speech” now, but the start and stop issue still persists. What do you advise to try next?
Still the same need from the start ![]()
https://developer.android.com/studio/debug/bug-report with Symfonium debug mode on.
When trying to generate the debug within Symfonium it says it failed and to consult support for files over 100 MB
I generated the full Android bug report as shown at the link, but the dumpstate log shows that the bugreport may not have captured all logcat content:
logcat: Logcat read failure: No such file or directory command ‘logcat -L -b all …’ failed: exit code 1
So the separate logcat and dumpsys audio files from the Duck test may be more useful.
Upload the bug report and log at https://upload.symfonium.app as per the docs please.
I’ve uploaded the recent debugs
It should generate a full zip file that’s what I need.
Okay I just sent them over
The bug report not the zip of the logs …
my bad, I just sent those ![]()
Well thanks for the time lost for nothing not only because not giving the proper things but asking for support because you use a bad crack …
I apologize, I installed from a third party. I’m going to feel like an idiot if that’s what’s been causing this. I’ll uninstall and reinstall directly from source. If that fixes it, I’ll send you the cost for the app.
Uninstalled and reinstalled from official source. it functions completely fine. I apologize for wasting your time. I heard about this app through a third party and never even installed straight from the store. Now that I have, it works beautifully. I have gone ahead and purchased the lifetime pass because this app looks awesome and I’m sorry for wasting your time.
