Subject: MusicBrainz IDs not exposed to external scrobblers through Android media session
I’m having trouble getting MusicBrainz identifiers recognized by external scrobblers when playing music through Symfonium.
My setup:
Scanner: Symfonium (Files - SAF)
Audio format: Opus (Vorbis Comments)
Scrobblers tested: Official ListenBrainz Android app and Pano Scrobbler.
Music collection: Primarily Japanese artists, with artist, album, and track names frequently differing from MusicBrainz’s canonical naming conventions.
My files contain the following correctly formatted MusicBrainz tags:
MUSICBRAINZ_TRACKID
MUSICBRAINZ_ARTISTID
MUSICBRAINZ_ALBUMARTISTID
MUSICBRAINZ_ALBUMID
Troubleshooting already performed:
Verified that all four MusicBrainz identifiers are embedded in the Opus files.
Confirmed that Symfonium is using the Symfonium (Files - SAF) scanner.
Cleared Symfonium’s tag cache and rescanned the library.
Confirmed that Ignore MusicBrainz IDs is disabled in the local device provider settings.
Confirmed that Scrobble as advertisement is disabled.
Disabled Track number in media session.
Disabled Explicit symbols in media session.
Enabled Expose media session queue.
Tested playback and scrobbling again with both ListenBrainz and Pano Scrobbler.
Unfortunately, the issue persists.
Questions:
Does Symfonium expose MusicBrainz identifiers, particularly MUSICBRAINZ_TRACKID and MUSICBRAINZ_ARTISTID, through Android’s media session metadata?
Are these identifiers parsed internally but omitted from the metadata exposed to external applications?
If they are not currently exposed, could support for transmitting MusicBrainz identifiers through Android’s media session be added in a future version?
These identifiers are particularly important for my collection because Japanese artist and track names can have multiple romanized, translated, or Japanese-script representations. MusicBrainz identifiers would allow scrobblers to identify the correct recordings and artists independently of their displayed names.
I’d appreciate clarification on whether this is currently supported or whether it would require a feature request.
- Tag flac files with Picard, applying the musicbrainz ID tags.
- Sync music files to my android phone using MusicBee. Flac files are converted to opus.
- Rescan library in Symfonium.
- Play newly added song.
- Check listenbrainz for active scrobble.
- Wait for song to finish playing.
- Check listenbrainz for correct mapping of song.
I used the Symfonium ChatGPT model to discuss the issue I was having. It asked questions and had me verify settings in the app, and then generated a support ticket to include all relevant information.
enlightenment117 -log
