No mTLS possible in secondary connection if primary connection local IP address (“https required”).
Subsonic (Open)
Add media provider (navidrome via subsonic) with local IP address.
When adding secondary connection (i.e. personal domain), there is the option to add mTLS support, but this cannot be saved, there is an error that mTLS requires https.
It’s not possible to add the primary server (in step 1.) as https and later add mTLS to the secondary connectionn.
I’d like to split these connections, when i have mTLS enabled my Denon X3800h is not able to stream continuously when I cast DLNA at home.
Not even when mTLS is bypassed. Just the fact that it’s turned on in Symfonium makes that is loses connection.
For the Denon interruption, could you send debug logs using this guide?
Enable debug mode before selecting the Denon, start playback and let the interruption happen, then disable debug mode and upload the logs promptly. Reply here with the upload description and the time the interruption occurred so I can find the right logs.
Your new logs show the server stream failing with an HTTP/2 PROTOCOL_ERROR at 07:41:21. That cuts off the audio Symfonium is relaying, and the Denon reports stopped at 07:41:35. Your recast then opens a new stream successfully.
This narrows the problem to the server connection used by the relay. It doesn’t yet show what caused the HTTP/2 reset. Which reverse proxy are you using, and does its error log show anything at 07:41:21 on October 24?
The Cloudflare app message shows a tunnel stream being cancelled, but without its timestamp I can’t match it to the playback interruption. Code 0 doesn’t tell me what triggered the cancellation.
The dashboard entry records a link_maze_injected action, not the HTTP/2 reset. Its HTTP/1.1 and GStreamer details don’t identify the failing Symfonium request either.
Could you include a few surrounding Cloudflare app log lines with their timestamps and timezone? You can keep the private fields redacted.
